$200 Karate Champ in CT
Cartouche
Southington, Connecticut
(ITEM IS SOLD THANK YOU)
totally working
Cab solid, no water damage. I repaired some gouging at the bottom w/bondo & paint touch-up
inside of cab very clean
cp looks good, all controls work fine
upper part of coin door mechs incomplete, but switches are there to manually coin up, or you can set to freeplay
monitor display solid, some KC burn-in (the vertical line in the photos is from camera)
bezel has minimal scratching, which is rare for this title - the diagonal line you see on the display is not a scratch, it's a wrinkle in the tinted adhesive sheet on the back of the bezel, which can be peeled off if desired
$200 you pick up, easy load from my garage in central CT near 84 and 91
