2 Smaller Gorf PCB Cards
Phetishboy
Avon, Minnesota
Are they the same? I pulled the stack out, removed them all to clean the housing and when I went to put them back, they had been moved from the 'order' stack I had them in. Are the 2 smaller ones interchangeable? Or is there a number/location screened on them that will help me put them back in the right place?
Oddly, they're all interchangable, well, I guess as long as they're facing the correct say. The order does not matter, although the manual probably shows some order.
Cool. They both look identical. "Ram Board" same serial numbers, etc. This worked before I took it apart so I'm just hoping I didn't eff it up trying to make it look pretty.
They're the same...
