cjs001
I am listing these for someone. Pick up is ground level in Fort Ann, NY 12827. $2200 or best reasonable offer for the pair.
Skee ball on left: boots and plays but sometimes gives extra 10 points or misses 10 points so micro switches will need adjusted.
Skee ball on right: appears to boot, display does its attract light show but it will not coin up, speculating connection issue to cpu from coin switch.
Both have some lamps out for score display. I believe there are some new bulbs with the games.
Both have their ticket dispensers present, functionality unknown.
Both had coin microswitch wires moved to a push button switch for coining up. Easily reversed for coin op if desired.
Two extra top netting with frame
Several extra balls
Several extra balls
