2 offroads, same issue?
AncientGames
Donor 2023, 2025
Ontario, Canada
hi everyone, I have 2 Super Offroads and both have the exact same problem. One for sure was working 100% then, a couple days later it wouldn't boot. When you turn it on the screen comes up grey with a bunch of short little lines vertically in the center of the screen.
If the battery goes dead, does this happen? Has anyone else had this issue and what would be the fix?
Thanks, Mike
i dont think those suicide...
would be a good idea to check your 5 volts on each machine just to make sure you dont have power supply issues
Thats ok on the machine. I put in a new PS and made sure all the voltages checked out while the machine was on. But its odd. When I saw the screen I was more than surprised since I have the exact same issue on another machine and can seem to find the reason. I plan on checking it out some more before i trash the machine. I have it FS on Maaca here in Canada at $100 and no takers. So, i figured i'll attempt to fix it one last time...if not then bye bye.
