I have 2 MK soundboards with a seperate problem for each. The 1st board has very dim sound even with the volume pot turned all the way up, i have replaced the audio amp and still have the same problem, zenomorp suggested changing the caps so I was wondering if anyone knew which ones I should replace. The 2nd board makes very loud static/scratching noise when it boots up but if fades to a very dim static after the game has been on a little while. You can still hear the game sounds in the background but the noise (like if you were driving fast with the window down) is loud at first and then fades to a dull background static. I had a working MK soundboard i put i my dedicated MK cab and it worked fine so I eliminated the volume pot and the speaker in the cab, so I am pretty sure these problems are on the soundboards. I would greatly appreciate any help or advice and thanks zenomorp for your help already!!!
__________________
__________________
