Got them delivered Monday. They both have tags from Showbiz pizza. But aren't metal so I don't think I can take them off with out ripping them. They are both the sa,e cabinet style. One of the 3 marquees is a little different. The board doesn't appear to work. The one that had the board the linear power supply came on with 2 red lights and the monitor had glow but nothing on the screen.
I was going to plug the board into the other one but the top part of the harness (Edge connector) came loose. When plugged up it has one red light and one yellow light. They will be major projects but I already knew that going in. First step will be to pull the monitors and test them in my Crystal Castles Mini. Then pull the harness in the good one and do a better rewire job than they did. May swap some chips from another board to this one.
