2 in 1 jamma switcher?
Hey, my 2 in 1 switcher will not run area 51 site 4 :S It's is running egg venture fine, but not the other. Its does not make any sense.
Does anyone have any advice?
those switchers have issues because most dont include the -5 volts on the second side. Area51 may require it. Some dont even have -5 on either side.
I would:
1) Figure out whether that board requires -5
2) If so, measure whether you have -5 on the PCB when plugged into the 2-to-1
3) If not, figure out the right way to route the -5
so i need to bypass the -5?
not bypass add/jumper/bridge, basically if one connector has -5 you'll want to splice a line into that and add it to the one that does not. if neither have -5 you'll have to add it to both (how you go about this is up to you), you can either run a line and jumper off it or run 2 separate lines.
Alright, that's what I meant. Thanks for the info. :)
I'll take a peak at my manual tomorrow and see whats up with this device.
The egg venture board works fine so I have no idea.
