solo742
If you have (Vector) WG 6100 games, this is a mod you need.
Got a couple (2) of these and have no more vector games, so here they are.
26 each shipped PP gift or add the fee (50 for both)
Brand new/never installed.
Details here:
The LV2000 now has a little brother, the LV2000 Light.
One of the most frequent failures of the Wells Gardner 6100 series XY color monitor is that the low voltage power section of the deflection board fails.
Anyone who owns a Tempest, Space Duel, or other Atari color XY game with a WG6100 in it has probably seen this problem. Something in the HV fails, or a deflection transistor shorts which causes runaway currents to be drawn through the low voltage section which in turn burns out the small regulating transistors Q100 & Q101 and some resistors!
And sometimes it just decides to fail for no reason.
The LV2000 is a low voltage retrofit which eliminates this problem. This small PCB replaces all the components of the regulating part of the low voltage section. On the original LV2000, the voltage is adjustable with two small potentiometers. The LV2000 Light has set voltages and which are not adjustable. Both boards have two LEDs indicating that the low voltage is being generated.
The only parts that do not get removed from the low voltage area are the large filter capacitors, the 4 diodes, and the power output transistors.
With the LV2000 retrofit installed, the low voltage power section of the deflection board should never fail.
PM any questions and thank you.
Details here:
