19v2000 help
caddysrule
Tracy, California
Hello all,
I got a Asteroids Deluxe it plays blind.So I capped it and changed all of the monitor chassis transistors and reflowed all of the header pins connectors.After all of this the spot killer is still on.All of the voltages are correct (on the AR board)and it plays fine blind.I tried to find a repair FAQ like the 6100 but I couldnt find one on the net.What should I check next on the deflection board to see what may cause the spot killer to be on.In case one of you guys may ask the neck glows and no fuses are blown..
Jeff
Ok I read this http://technical-department.servegam...WG-19V2000.pdf...
A couple of questions...
What should I test first..
Should I measure the 90 volts?
Well this is my first 19v2000 and Im not really understanding the schematics.
Actually I dont know what transistor to test and which one cuts off Q503 and Q504..
Hmm Im just lost someone point me in the right direction LOL
Jeff
