davemcl
19V2000 HV problems
I have a V2000 that came out of an omega race running in an asteroids game. Game board known to be good. I'm not a newbie to the hobby, but a newbie to working on the vector monitors.
I've read the FAQ & Guide forwards & backwards a couple times, searched the monitor forums & don't seem to find this problem anywhere. The def. board & HV board have both been recapped, transistors & diodes seem to check out OK & voltage readings on the deflection board at P500 all checked out OK with the exception of pin 2 which read a little high, I think around 33.6V instead of 30V. All voltages were tested at P900 of the HV board & checked out,, pin 8 read about 39.7V instead of 38V listed in the manual. Voltages were tested with all connectors plugged in at the back of the connectors with a digital multimeter. I've turned down the brightness & contrast on the deflection board to the minimum to get a decent picture & turned the focus adjustment at R909 counterclocwise to the point that the picture is still in focus. I don't presently have a working high voltage probe, so I haven't messed with the votage adjustment at R905 on the HV board. The HV board has a new HV diode in the oniginal holders, dielectric grease on both ends. I can play 4-5 games & then the 1.5A fuse at F102 blows. I did have 1 time last week when the fuse at F600 blew, but after replacing, it hasn't blown again. This time, the fuse blew at F102 & I saw some smoke come from the HV unit. It was mounted in the metal cage mounted on the monitor frame, perforated cover left off so I could see what was going on.
I noticed the resistor at R900 was hot enough to fry an egg on & that some of the dielectric grease had cooked out of the HV diode end by the holder on the red anode wire side. I also notice that a small peice of the rubber or plastic cover on the HV trasformer (flyback) chipped off. I'm 99% sure it wasn't that way before I reinstalled the monitor this time. I have an extra HV board, but before I take the flyback off there & install it or just pull the HV diode & put it on that board, I'd like to know what's causing this. I'm thinking maybe the CRT is getting too high a voltage (higher than 14,800V) the manual says 14,500V give or take 300V, but since no probe, I can't test it. Would the excessive voltage cause R900 to heat up & maybe cause F102 to blow as well? I'm stumped, I'm hoping one of the experts can shed some light or make some suggestion where to look or what to check for faults.
I should mention that I've tried the monitor on a working astroids deluxe game that never gives me any problems with the G05-802 installed in it & tried it with another working asteroids board in a different machine. It does the same thing regardless, so I think it is isolated to being an issue with the monitor. The big caps on the defletion board have not been replaced, but appear to be alright.
Dave
Dave
