19v1001 odd question
Arthur Dent
Donor 9 years: 2015-2022, 2025
St Louis Area, Illinois
I am curious if anyone know what the spring like coil of wire attached to the chassis is. I thought maybe my SI has something not attached properly but every picture I have seen just shows it by itself.
If the monitor was in its normal mounts then it would be touching the tube but because Space Invaders has the chassis mounted on a shelf below the tube it does nothing and instead there should be a yellow ground strap going from the chassis to a metal piece that attaches to one of the bolts that secures the tube which in turn touches the tube/dag
Ah, I see. So it just isn't used in the configuration it is mounted. I do have the yellow ground wire in place. Thanks for the information. Very informative.
