19V1001 are P277 and P292 boards interchangeable?
RobotWorkshop
Donor 2025
Michigan
I've seen 19V1001 black and white monitors that use a P277 and others with a P292 board plugged onto the chassis. Trying to find out if those boards are interchangeable or if there are differences on the main chassis where it makes a difference which board is installed and has to match.
If there are differences in the rest of the chassis what are they and how to tell which board should be installed. Or if that isn't a concern and either board could be used.
That helps! Thank you. Just the confirmation I needed.
Easy.
was an odd ball service manual that covers the different types of monitor,
i remembered seeing this years ago when refurbishing my Space Invaders II
there is also a 19V1002 model that has a Vertical adjustment pot on the chassis,
this needs an external 13v power supply
