19k7951 wells b+ test problems
security0001
Donor 6 years: 2020-2025
Montana
where is the proper test points for checking the B+ on the monitor and where is it adjusted at??
thanks for any help.
also this monitor needs caps and is there anything else that should be replaced/fixed at the same time?? any common parts that should just be replaced.:D
you can't adjust the B+ on a K7000
measure it on the big wite resister that hangs on the outside on the left of the chassis. on the tab closest to you.
it should be 132v for a 19"
yes cap it and replace the flyback and reflow the chassis and neck board.
Peace
Buffett
