19K46XX blowing fuses, flyback?
keithsarcade
St Peters, Missouri
Have a 4600 thats blowing fuses. Adding a jumper wire only blows the main fuse in the game. Looks like the game will be a part out at this point, also has board issues, but just wondering possible culprits for the monitor. Any ideas? Also is it is the flyback, can I even find one?
Does the game have an isolation transformer? If not, then that's why. Otherwise, check the HOT and VR.
BTW - NEVER jump a fuse to "see if it will work". All you'll accomplish is causing more damage... :rolleyes:
The vr is the voltage regulator. It kind of looks like the hot but is mounted on the other side. You check them with a multi meter so they are not shorted to ground
So highly doubtful my flyback is bad? I would think it would have sprayed out with the jumper attached. Still not sure on how to test the hot and VR, but I guess they are cheap enough to replace.
OK, I replaced the hot and VR, changed the fuse and gave it a cap kit for good measure. Now its not blowing the fuse anymore, but still not working. Originally it was getting power but no neck glow. Then I noticed the neckboard had a small chip missing from one corner which damaged a trace. Repaired it, and now its not getting power either. Fuse is still good. Any ideas?
still might be the flyback.. the 4600 was once considered one that never failed. however I am now seeing the start of 4600 fly failure. what about unplugging the large plug from the flyback to the mainboard.. see if it still blows the fuse..
