1991 konami simpsons
woodrailsrus
jennerstown, Pennsylvania
i was feeling adventurous tonite after fixing the joystick on my dig dug so i started to try to fix my simpsons......
first i adjusted the brightness, someone had it turned all the way up
BUT
i am trying to figure out how to shrink the size of the screen horizontally. i see the one knob will adjust the screen vertically.....but the problem i am having is my picture is a small amount too wide.......one side it will cut off the "insert coins" at the top and if i move the screen the other way it will cut off how many lives the 4th character has.
this may be a stupid question but im not sure if this is an easy fix.......i could live with it the way it is......but i thought you expert might have an idea?
thanks for that site guy, where is a good place to get those plastic adjustment tools? it says not to use metal at all......i dont no much about fixing monitors at all but i have heard before that you need plastic tools
