Zitt
I have also been attempting to paint match the cabinet plastics against some powder coat - and learned something neat for future projects; but before all of that ... I want to paint match against powder coat because my chair controls have began to peel and rust. They'll need to be redone.
I started by measuring the sRGB color of a retr0bright-ed side panel using my Panatone(r) Color Cue(tm) device which I got off of Ebay several months ago and it came up with r246 g230 b198. I pulled these values into the RGB to commercial Tints page at EasyRGB.com. This gave the closest RAL numbers which to match to. I then went to google and did a search for RAL-1013 powder coat which returned a result to powder365.com for their " Oyster White " powder coat. Then using the HTML code #F6E6C6
I used the RGB browser to convert to "RAL Classic" listed six colors with % equivalent matches to my original scanned color.
% 1-ΔC Color name
96% RAL 1015 Light ivory
94% RAL 1013 Oyster white
93% RAL 9001 Cream
92% RAL 1014 Ivory
90% RAL 9010 Pure white
89% RAL 9002 Grey white
I also did searches for other color combinations and ended up selected the following three colors from powder365.
1 x RAL 1013 OYSTER WHITE (340/10MIN)
1 x RAL 7035 LIGHT GREY (340F/10MIN)
1 x TEXTURED ALMOND (380F/20MIN)
The idea was to put each color on a test peice to see how close to match and pick one which looked the best.
During my research; I also came across a post to caswellplating.com's forums which talked about mixing the powder with MEK to "melt" the powder into liquid form. This sparked an idea - why not use the MEK to mix powders together to get an even better color match. I have a quart of MEK in the garage - so time to experiement.
I knew the grey wouldn't really match - it was too grey; so I used MEK to melt it and used a hobby paint brush to apply it to the scrap peice. I then used regular power coating equipment to lay down the almond and oyster for comparison. For the last color; I decided to mix some grey, 2 TSP of pure white (purchased at Harbor Freight), 2.5 TSP of oyster together with a generious helping of MEK to turn the powder to a grey-white "milky" forumation. I applied this with a paint gun:
From Left to Right: RAL-7035+MEK (under thumb), Almond, RAL 1013, and MEKMix
The Right most Grey is "uncured" IE that is how it goes on being applied with a paint gun. Looks fully cured already. and the lines were created with standard blue painters tape.
With MEK; it looks like one could color match any color given enough patiences and primary colors to choose from. I look forward to futher experiments.
% 1-ΔC Color name
93% RAL 9001 Cream
92% RAL 1014 Ivory
