1980 Electrohome color knobs
videodan
Donor 3 years: 2023-2025
Melrose, Massachusetts
Where would I find these knobs on the 25"? The colors on my Eagle are way off, and I'd like to adjust it so it looks right. Thanks!
Probably Bob Roberts.
Or you could just find the type and size, and order them from somewhere on the net like Mouser or Digikey...
IIRC, the drive pots on a G07 are 220ohm, and the cutoff pots are 5kohm, but I'd double check. Bob Roberts will have them, as will Mouser, Digi-Key, or any other electronic supplier.
-Ian
What I meant was, where are they located on the monitor itself? It's a matter of going down 2 flights of stairs to get the colors where they should be. Thanks.
You said 25" and Electrohome, so I assume it's a G-02. There's an entire series of pots located on the front of the metal "pan" everything's mounted on. The red, green, blue adjustments are there....as is screen and a few others.
Edward
Thanks, ELutz, I didn't know which knobs to go after. Also, the labeling is a bit faded, so it makes it tough to read. If you know the exact knobs to turn, please let me know.
They're on the opposite side from the power transformer. The knobs are generally colored red, green, and blue. Also, shine you a good light onto it....the words red, green, and blue are stamped into the metal above the corresponding pots.
Edward
