i just pick this machine up loved it as a kid but it has some issues i need some help with,fist off the battery did leak onto mpu i removed it from the board the machine would turn on but would not flash the 7 times i cleaned up the mpu board & resolder some of the spots plugged it back in still not flashing 7 times but know like 5 times,also found flipppers not working checked fuses found f4 fuse blown,checked & found right flipper melted pluger jammed inside sleeve replaced coil & sleeve cleaned up pluger slides nice,replaced fuse found machine will boot the 7 times but when you start using the flippers found seems like a big amp draw & f4 fuse will blow again trying to trace a short,also found the knock down target coil getting hot i removed it just to see if that would help,would the f4 fuse blow do to not having the knock down coil installed i don't think it would need some advice also found the large resistor on the solenoid driver board a little black but it seems not to have a short i replaced the eos switches also not sure if the wiring is correct on coils does any have the exact way the should be wired not sure if the guy wired them corrctly any help would be appreciated thanks
