Picked this up for a good price, but it needed alot of work. MPU board was toast due to acid damage, harness was cut and spliced at certain connectors with wire nuts, rectifier board was fried and had the wrong mount for the transformer, playfield was roached, every insert was concave, mylar was peeling and bubbling and brittle, some sort of white "fuzz" under the playfield (not sure if it was mold or not), and thats just the start. So far i have removed the backbox panel and stripped it, tumbled all the lamp sockets for 24 hours, repainted the board, reinstalled all the lamp wires, repinned every connector in the entire harness due to corrosion (almost 400 wires), rewired the backbox to support the new 7 digit displays that will be put in, purchased a new CPR playfield, backglass, and plastics set. Im in the process of swapping and cleaning and rebuilding each part. The ball return ramp was a complete mess, but after alot of sanding, cleaning and polishing i think it turned out well. Flippers were rebuild because they were rusted solid (had to break them to get them apart) ball launcher was also rusted solid, moves like butter now. before and after pics:
