ReallyRotten71
The rundown - This is a functioning machine that needs some work to be perfect.
Cabinet - Solid, a few scrapes/dings emblematic of a game from 1975. Could use a new paint job and minor touch-ups.
Playfield - Relatively clean minus one wear spot outside of the kicker hole - which is typical for this game. Some of the inserts/relays also have miniscule amounts of wear around them.
Plastics - The plastics are decent overall. The top left plastic has a chip out of it however, and the middle plastic on top of the roto unit is split. These plastics seem quite difficult to find and are not reproduced.
Backglass - The backglass has flaking typical of this game. This could use a touch-up job or a replacement - but it isn't a game changer imo.
Mechanics - The main issue with the game is the roto unit. The roto spinner doesn't spin as powerfully as it should firstly. One of the numbers fell off as well (I still have it), and a few of the numbers aren't fixed well to the roto unit. A previous owner tied some of them on with wires, but there may be a better way to fix the numbers on.
Spare Components - New flippers, flipper rebuild kits, plastic posts, pal-nut wrench, roto unit springs
Asking $600. Not looking to ship. Located outside of Harrisburg, PA - 17112.
