cavallonero
Hi Folks, I have a 1972 williams base hit - pitch and bat machine.
Everything works fine , until an out is made, then the outs will cycle through out 1, out 2, and out 3, then the game ends. So, whenever you get one out – the game cycles through all the outs and ends. I have cleaned the stepper switch associated with the outs (located behind the backglass). That did not help. I also cleaned and adjusted the contacts on the out relays (this didn't help).
The outs are recorded with 3 lights – there is no score reel designated to display the outs – just 3 separate light bulbs - fyi. So, if anyone has any ideas – that would be great.
John
John
