Sean Duffy
Hi All,
I'm hopping for a little help. I have a Bally Congress Bowler that was working just fine played weekly. Then in the middle of a game the frame unit step up coil and the player up unit reset coil stuck on (energized) this happens in frames 2 and 4. If I manually advance the frame unit the past the fourth frame it advances as it should with the exception it only lets you have one throw regardless of whether there was a strike or not. I do have a schematic and manual, but just cant see the problem. Any help is greatly appreciated.
Sean.
Sean.
