19'' Zeneth monitor problem
Gambeno
Rocky Mount, Virginia
19'' Zeneth monitor problem (Sync issue)
Last night I was playing around with my playchoice 10 and I accidentally unplugged the control switch for the settings (not sure what the switch is called but its for adjusting the monitor from the front). Anyway the machine was on when it came unhooked and the screen went totally scrambled. I tried to plug the switch back up but it started having a burning smell and only the vertical position would work on it so I'm guess its fried. So I went ahead and pulled the monitor out to repostion the screen from the back and got it fully adjusted except the screen is off to the left a lot. Its almost like the picture is to wide for the screen. I tried for hours messing with the horizontal position but if I moved it over to much it would scramble the screen. I could get it almost perfect sometimes but if I turned it off and back on in that setting it would rescramble the picture. I was wondering if i adjusted the width coil would this fix the problem? Ive never messed with a width coil before so i'm not sure if this would help or not.
Thanks,
Kane
if you havent done it yet cap it and replace the h hold pot. several of mine did that, and after i replaced every thing it fixed it. i had full range of adjustment again. also check to see if your screen position jumper is in the correct position that helps alot. check your B+ if it is off to much you wont be able to adjust it verry well either or it wont lock in and stay after the game it turned off and on again.
Peace
Buffett
Hopefully Ill have so time tonight after work to mess around with it a bit more and maybe post a video. Wish me luck lol
Thanks,
Kane
