19" VisionPro Horiz Collapse Question
arcadeaction
Donor 2013-2014
Gainesville, Florida
I have a 1901CN VisionPro that shows horizontal collapse (a vertical line down the middle about 1/8 thick when the monitor is sitting horizontally). The game PCB works fine.
When I physically lift and lower the remote board with the adjustment pots, I can hear "electronic crackling", so I'm wondering if anyone thinks the remote board is bad or the remote board connections just need to be reflowed or if I likely just need a new HOT transistor. I am just asking as once I had mistakenly powered up a different monitor without plugging the remote board in and the result was similar until I shut it off and then restarted with the board plugged in (this was a 25" k7000 however).
