19 inch B&W Motorola Horizontal Collapse
Here, I re-arranged your pics to match up with the diagram. Use the black & white diagram as a guide to see what needs to be connected to what. You will definitely need to repair the broken trace on the bottom blob, and hook the two blobs up together too. One jumper wire should be able to span all 3. I drew in a blue line to show an alternative layout of a jumper wire, just make sure it's insulated from the traces it will cross over.
That should be the only thing you need to check in that area of the chassis.
attachment.php
