curtislv426 Well-known member Donor 2013, 2016 VAPS Joined Oct 25, 2013 Messages 3,194 Reaction score 1,418 Location dayton, Ohio Sep 20, 2020 #1 Hi guys. Would a 19 and one board display correctly with a medium resolution monitor?
mgkastra Well-known member VAPS Joined Dec 18, 2011 Messages 5,488 Reaction score 2,016 Location Mobile, Alabama Sep 20, 2020 #2 No. It can either do High resolution or standard, 15khz or 31khz. Can't do 24khz medium.
OP OP curtislv426 Well-known member Donor 2013, 2016 VAPS Joined Oct 25, 2013 Messages 3,194 Reaction score 1,418 Location dayton, Ohio Sep 20, 2020 #3 mgkastra said: No. It can either do High resolution or standard, 15khz or 31khz. Can't do 24khz medium. Click to expand... Thanks my friend for a fast response !
OP OP curtislv426 Well-known member Donor 2013, 2016 VAPS Joined Oct 25, 2013 Messages 3,194 Reaction score 1,418 Location dayton, Ohio Sep 20, 2020 #4 I'm assuming a 60 in one would also not display correctly in a med res?
john2654 Well-known member Donor 3 years: 2011, 2020, 2024 VAPS Joined Mar 30, 2010 Messages 6,426 Reaction score 1,272 Location Rhinelander, Wisconsin Sep 20, 2020 #5 curtislv426 said: I'm assuming a 60 in one would also not display correctly in a med res? Click to expand... Correct. Runs the same as the 19 in 1.
OP OP curtislv426 Well-known member Donor 2013, 2016 VAPS Joined Oct 25, 2013 Messages 3,194 Reaction score 1,418 Location dayton, Ohio Sep 20, 2020 #6 john2654 said: Correct. Runs the same as the 19 in 1. Click to expand... Thank you kind sir
