SilverDuck
I have the 19" low ohm Alva chassis, and I'll be damned if I can get it to sync.
There is a single pin up near the degause connector that is labled "FG". What is this?
The single pin on the neck board....where does this connect to?
The game is a Sega Super-Hang-On upright, and the monitor it had was a W/G 19K7901.
The game's sync wires are white, and blue/white stripe.
The chassis sync is white only, with a black labled E. Is this "Earth Ground"
The chassis came with a black cable, single female pin connector, with a spring and some braided conductor on the other end, and a spring. What is this?
