hatrick
I had a co-worker give me an old wood grain Zenith TV from the 80's. I was expecting to find a nice tube I could swap into a G07.
Opened it up to find tube number A48AAX02X. Checked the BK setup chart to find it's a CR23 and 6.3 volt heater. Looking good so far. Then as I'm brushing away some dust I see 19v100. That's a 100 degree tube right? I've found the needle in the haystack TV that has the 100 degree tube.
That would be great for a 6100 if I swapped out the neck connector, but I don't have any 6100's. Can this tube be used successfully with a monitor that uses 90 degree tubes?
