15khz RGB to composite video
Tighe
Richmondville, New York
I would like to be able to combine the RGB signal from my games to composite video so I can live stream the video without pointing a camera at my game.
This is the only thing I have found so far:
http://www.ambery.com/rgrgtotvcosc.html
also I could use the RGB to composite/s-video board that is in my Propcycle, but I would prefer to not have to take it out of my Propcycle everytime.
I wouldn't buy from them!
They think Pac Man is a fruit machine.
so wait, what was your question?
I have one of these in a DIY cabinet and I'm using the S-Video output and the picture is great:
http://www.jammaboards.com/store/rgb-to-ntsc-pal-tv-converter-pcb-cv-04.html
I didn't buy it from Jamma Boards - I got it off of E-Bay and it looks like if you search for "weiya rgb converter" you can find similar items on E-Bay.
The only warning I have on that one is the manual didn't really say if the ring or tip of the connector was +12V. I can't recall what it ended up being, but you can figure it out by following the traces from the power connector to other GND connections. I initially hooked it up backwards and started smoking wires...but no harm to the board.
The JROK ones look to be the same functionality as the one that @smalltownguy2 and I mentioned. If I would have known about it at the time I would have bought that instead to support a forum member.
