15khz on a 31khz monitor
SkyyCorvus
Jamestown, New York
What is the most feasible way to run both 15khz and 31khz games?
I have a few 15khz games that I don't want to have to buy a new monitor for.
I tried one of the cheap cga to vga converters for like 25$ and it doesn't work well, it displays glitched video.
the video is rolling and artifacting.
I wouldn't mind buying a slightly more expensive converter, but wanted to ask if anyone has had a good experience with a particular unit before I buy one.
The one I have is similar to this, except it has one vga out.
http://www.starlitegaming.com/Parts_and_Accessories/Converters.html
I was wondering if anyone has tried one of these.
http://www.ambery.com/rgbcgatovgac.html
Please let me know what the best way to go about this is,
i've heard good things about the XRGB converters, I'd really rather not spend that much though.
I've got a couple wells gardener 19" k7203s that have a switch to change the kHz.. Are you looking to use one cab, and swapping in pcbs? Then buy a switchable monitor.. As it's the most stable option and it's a breeze to switch if you run the wires into your coin door.
Not Possible
If that were possible I would, but I do not have the space, or the money for a second monitor at the moment. I need a solution to make the one I have work.
