15 pin Trisync Monitors?
HighScoreSaves
Donor 7 years: 2013-2019
Blaine, Minnesota
I have a few of the Trisync monitors that have the 15 pin VGA (SVGA?) connector on them. I want to see if anyone's made an adapter that ties into a harness? I really don't know what game I'll be using them on.
I think it should be as simple as finding the pinout to the 15 pin and going from there. Am I making this TOO easy?
What are you looking for? All tri-syncs I have seen have both the standard ten pin connector used on CGA/EGA and the 15 pin connector. You populate only one and then throw a switch or swap a connector.
yeah lets find the pinout on google:
http://pinouts.ru/Video/VGA15_pinout.shtml
and the cheapest adapter your going to find is going to bew buying a cheap standard vga cable, cutting it apart and making your own adapter....
if those dont have atandard video input pins then you might have straight vga/svga and nothing else.. you might want to research them a little more...
That's pretty much what I figured. I guess it was that easy, thanks!
im thinking get cables like these cut in half, and theres 2 adapters per cable lol
http://www.mycablemart.com/store/cart.php?m=product_detail&p=1717
