FS Parts: 13" Wells Gardner chassis, yoke and TV tube
1971camaroguy
Arkansas
Wells Gardner K7200 Chassis, Yoke and replacement TV tube in a Pacman Cabaret frame
History on this - I bought the chassis and yoke from a working set-up
Found a TV tube at the local goodwill that was a darn near match, swapped the yoke and installed this set-up onto a pacman cabaret frame that originally had a different chassis in it. It had different mounting points so i used stand-offs to support it.
The Good: I had this actually working and looking pretty good on the bench using a iCade board (see picture)
The bad: After I built the arcade, and installed the monitor (same iCade board, different harness), I never could get the picture dialed in like it was on the bench. I ended up giving up and put a LCD in the cabinet instead. The picture was real garbly and nothing I did was working to get it to come in clearly. Nothing changed other than I was using a different harness, so I am not sure.
So you may hook this up to your set-up and it might work great, or you might need to do some work. It's never had a cap replacement as far as I can tell. This just needs someone that knows what they are doing, because I obviously don't.
Selling as a parts only / repair sale because of this, no guarantees.
$160 + shipping
Ok Thanks
I was under the impression that the K7200 chassis was simply a 13" version of a K7000? Maybe there are some numbers or markings on the chassis I could tell for sure?
Either way it's a K7000 chassis that came out of a 13" cocktail cabinet
Let me think on it, I already have this packed up and ready to ship as a complete unit. I'd like to sell it like it is first as all I need to do is put a label on it.
If I don't get anyone wanting this as I have it listed I might considered it. Trying to safely pack a tube is going to be a pain, and I really want to keep the yoke with the chassis.
Alright.
I really don't need a second chassie.
Let me know if you decide to do it as well as what type of price.
