In case anyone else had the same question as me I thought id post my findings. This was sent to me from Tim at jammaboards.com:
Since the 1069-in-1 unit can also support 3rd/4th player controls as well, you can also do this in your cabinet.To connect the 3rd/4th player controls into the 1069-in-1 unit, you will need to use the small 3/4 Player JAMMA card which is included with the unit (this is the card with all the little buttons on it and a JAMMA connection).
Also you will need to connect another JAMMA harness into your cabinet (so you will actually then have 2 JAMMA connections,
your main JAMMA harness with your 1st and 2nd player controls and now the second JAMMA harness which will handle your 3rd and
4th player controls).
The first JAMMA harness will be your existing one which would connect to the JAMMA connector on the 1069-in-1 unit.
The second JAMMA wiring, the only part you will wire up is the player controls and power (+5VDC, +12VDC, and Ground which
you can connect to the same power supply the first JAMMA harness is connected to). Do not wire in the audio, video, etc on
the second JAMMA connector. Your 3rd player controls and buttons will wire to the 1st player connections on the second JAMMA
connector...and all your 4th player controls/buttons will connect to the 2nd player wiring on the new JAMMA connector. Then with
the little JAMMA card that came with the 1069-in-1 unit...plug that into your new installed JAMMA connection (for the 3rd/4th players).
