FS Parts: 128 in 1, Blue Elf, 200 in 1 Jamma Harness Adapter
armi0024
Donor 2012
Minneapolis, Minnesota
Ok, so we have had some issue with shipping, but.... :) We don't just resell products we actually design new ones to make your life easier!!!!
Hooking a new 6 button "Jamma" board up to a Jamma cabinet? Guess what, the 6 buttons are not on the Jamma Harness, but they are here:
Allows simple and easy installation of the modified jammaboards into a jamma cabinet with NO soldering, NO crimping, and NO harness modification, just plug and play! Comes complete with the wiring you need to connect buttons 4-6 and attach a video converter.
Which 6 button boards work with this adapter?
Blue Elf
Blue Elf 2
**new** 128 in 1 (horizontal board)
**new** 200 in 1
Red Box
Happy Fish
Happy Fish 2
**New**Kung Fu King
And a bunch more... Also this board allows you to easily connect a Gonbes adapter to convert from VGA to CGA that feeds directly into the Jamma harness or tap the CGA signal to use a Gonbes board to convert to VGA.
This little simple board saves loads of time on installation, is very versatile, and is only available at Paradise Arcade Shop.
We will be adding 128 in 1's as well as several other new boards in the upcoming week. Adapters are 25 when purchased alone or 15 when purchased with another board.
We also have a Gonbes/adapter special for easily converting CGA games to VGA screens:
Question that came in.. yes that quick
"if you dont have that adapter, how does blu elf 2 hook up other wise?
does it use jamma plus?"
These boards do not use a Jamma plus, the put all the buttons into the harness and remove a ground pin. This adapter does this simple conversion but also allows you to plug your buttons directly in with the .187 quick connects on the harness included.
I saw this on your site the other day. Nice!
Can I see some photos of the hollow euro stick shafts? What size dust washer fits it? Can it accept sanwa ball tops?
Thanks tighe
We have 6mm threading for standard ball tops and 10mm threading for the new Rgb tops, the 6mm threaded sticks have 10mm shafts for washers, the 10mm ones take standard happ washers. I will take some pics tomorrow.
This is really, REALLY cool and very useful for anyone who wants to do a quick convert job!!!
edit: the extra buttons are for Player 1 and Player2, right?
Blue Elf
Blue Elf 2
**new** 200 in 1
Red Box
Happy Fish
Happy Fish 2
**New**Kung Fu King
How much are they? Can't find them on your site.
hey bryan is this something i could use for the 3000 in 1 board if i have a 3 button jamma cab im gonna convert to a 6 button?If so can i order this @ the $15 price and combine with my board shipping?
I'd like to know this as well - my 3025 is processing and would def grab one if it works.
