IAM/KLOV Coin-op Videogame, Pinball, Slot Machine, and EM Machine Forums
Go Back   IAM/KLOV Coin-op Videogame, Pinball, Slot Machine, and EM Machine Forums > Arcade and Amusement Machines > Technical - Videogames - Monitors
Register iTrader FAQ Calendar Mark Forums Read
Reply
Thread Tools Display Modes
  #1
Old 07-28-2009, 05:33 PM
chas010 chas010 is online now
Senior Member
chas010 is an unknown quantity at this point
Default Dangers in cleaning monitors
Is it possible to over clean the back of the tube where the anode cup seats? I remember reading about aquaduaug(sp?) coating and its importance. I cleand where the rubber cup seats and wasnt sure if grime was coming off or special coating.
  #2
Old 07-28-2009, 06:14 PM
75ohm's Avatar
75ohm 75ohm is online now
Senior Member
75ohm is an unknown quantity at this point
Default
Depends on what you're cleaning it with, I suppose. I haven't had any problems with alcohol, electronics cleaner, windex, simple green on a rag, for any of it... wouldn't use anything with industrial solvents, like MEK, etc.
__________________
www.rennwish.org
Tron - Time Pilot - Multicade cocktail - Little Chief EM.
  #3
Old 07-29-2009, 04:14 PM
bjk7382's Avatar
bjk7382 bjk7382 is offline
Senior Member
bjk7382 is an unknown quantity at this point
Default
There will be a large area of clean glass around the anode hole. After about three inches away the aquadag will start. Some types are able to be cleaned, and some come off easlily with just water. Try it in a small location with a light colored cloth and then look to see if any/how much came off. It is usually alright to just wipe the entire tube down with a damp cloth to get the dust off of it. (discharge first!)
__________________
Vids: Asteroids Deluxe - Donkey Kong - VS. Unisystem - Mr. Do! - Bubbles - Space Invaders - Ms. Pacman (96 in 1)
Pins: Rescue 911 - Grand Prix
  #4
Old 07-29-2009, 06:05 PM
Spyridon's Avatar
Spyridon Spyridon is offline
Senior Member
Spyridon is an unknown quantity at this point
Default
Quote:
I've heard of people taking the monitors outside and hoseing them down. Any issues with that?
__________________
After Burner II, Arkanoid^3, Asteroids Deluxe, Centipede, Donkey Kong w/ DKII, Front Line, Galaga, Gauntlet, Gorf, Gyruss, MAME, Mappy, Multi-Williams, Pac-man, Phoenix, Punch-Out!!, Satan's Hollow, Star Wars, War Gods, Vanguard
  #5
Old 07-29-2009, 06:39 PM
bjk7382's Avatar
Senior Member
Default
Quote:
I would still test if the dag is water soluble before that, but I have only heard about certain types of monitors that the dag comes off of, never actually seen any. If you can rub the back of the tube with a wet cloth and it doesn't take hardly any of it off then hosing it down will probably work well.
__________________
  #6
Old 07-31-2009, 11:19 AM
komodo's Avatar
komodo komodo is offline
Senior Member
komodo is an unknown quantity at this point
Default
Hosing is fine if you have discharged the monitor and DO NOT rub on the black stuff on the back of the tube. If you do the aquadag will come off. I do it on just about every monitor/chassis I repair. make sure you dry the chassis and tube thoroughly before applying power to it again. Not a problem here in Texas. I just leave the chassis in the sun for about an hour and rotate it to get the water to drip off. The black stuff looks like it was painted on in a set pattern. A grounding strap made of metal usually runs across it at some point. Here is a photo of a K7000 repair I did. I have been meaning to get a user guide to doing K7000s up but haven't had the time.
Some day.
http://picasaweb.google.com/pat.dani...eat=directlink
__________________
Pat Danis
I have seen Noice's turtles and many of you have not.
  #7
Old 07-31-2009, 12:12 PM
KillerKades's Avatar
KillerKades KillerKades is offline
Senior Member
KillerKades is on a distinguished road
Default
Question on the hose down:
Shouldn't you cover the anode hole so water can't get in? Or does it really not matter.
__________________
Killer
  #8
Old 07-31-2009, 12:19 PM
bjk7382's Avatar
Senior Member
Default
The hole is sealed on the inside. After hosedown make sure you let it dry and maybe stick a q-tip in there to get it all out.
To me hosing down the tube seems like a lot of work. I usually just use some shop towells and mild detergent and wipe it off. And it still looks like brand new. Chassis on the other hand I have sprayed down since they get so dirty and they have a lot of little areas that are hard to clean.
__________________
  #9
Old 07-31-2009, 01:32 PM
Pac-Fan Pac-Fan is offline
Senior Member
Pac-Fan is an unknown quantity at this point
Default
As long as the aquadag is not water soluable, the hose down is the easiest thing to do. Gets the crud out everywhere including under the yoke where it builds up. Add a little dag-safe cleaner and you end up with a very clean tube, frmae and chassis. Use a paint brush to wipe all areas under the yoke, between rings, and between components on the chassis without having it apply too much pressure. No disassembly required unless you want.
  #10
Old 07-31-2009, 03:11 PM
nuterpacman nuterpacman is offline
nuterpacman is an unknown quantity at this point
Default monitor cleaning
I usually do not do that but sometimes when the tube has so much buid up of dust and smoke built up from bars that i have seen voltage from the anode walking down the outside of the tube to ground that taking a hose to it has been done but let it air dry for days or take a hair dryer after it.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
cleaning hot00frb General Arcade and Videogame Discussions 4 12-30-2008 10:39 PM
CPO Cleaning Krajkerjac Technical - Videogames - General Repair And Help 9 04-05-2008 08:44 AM
cleaning cp _sentient_ Technical - Videogames - General Repair And Help 3 03-05-2008 10:55 AM
CL dangers.. Our Mich "women" will get you Leinhit Chat About Almost Anything 19 01-31-2008 03:08 PM
Cleaning monitors Spbeyond General Arcade and Videogame Discussions 4 07-10-2005 08:47 AM
