IAM/KLOV Coin-op Videogame, Pinball, Slot Machine, and EM Machine Forums Return Home to Main Site
Go Back   IAM/KLOV Coin-op Videogame, Pinball, Slot Machine, and EM Machine Forums > Arcade and Amusement Machines > General Arcade and Videogame Discussions
Register iTrader FAQ Calendar Mark Forums Read
Notices
Reply
Thread Tools Display Modes
  #1
Old 06-30-2009, 05:34 PM
JeffC's Avatar
JeffC JeffC is offline
Senior Member
VAPS: 10 Games / 4 Boards
JeffC is an unknown quantity at this point
Default SmashTV + Total Carnage + Mike's Double Jamma
There's been some good Smash TV discussion here lately, so I'll add my latest project:
Here's where I reveal myself as a Jamma noob - I'm trying out the Mike's Double Jamma adapter. It seems to be a very well made item, and works perfect except for one glaring problem in that it doesn't pass pin 25 through. Not sure if that's described right, but the device seems to take all of the pins from the game harness, and "split" them, allowing you to connect both boards, then switch between them. When I hold the adapter up to the light, I can see that all of the traces that do this. Literally every edge pin on the harness side has a trail that splits and goes to each of the corresponding pins for the two boards you’re connecting…except for pin 25 (and its letter counterpart on the other side) which goes no where. In Smash TV, this translates to not being able to shoot right (direction right).
Starting from the left - 28 and 27 are grounds, 26 is for a button to switch between games, its going through a jumper and some other stuff. 25...nothing?!? I must keep all my enemies on my left side!! Then every other pin goes through various components and then to it's two counterparts on the othe connectors:
The only other issue I can see is that by default, you swap games by pressing P1 and P2 at the same time. In Total Carnage, the same button is used to drop bombs. I'm afraid that during a 2 player game, it might be easy to be bombing at the same time and accidentally swap games. I think the pin 26 button disables the P1/P2 swap function, but I'm not sure.
Other than that its fine…no issue with the video with my single power supply, or anything else. Anyway, I'm going to work on it more tonight.
I also want a mod that makes the Smash TV announcer say "SKATE OR DIE!!!"
__________________
The 720 Zone
  #2
Old 06-30-2009, 05:42 PM
m_mcgovern's Avatar
m_mcgovern m_mcgovern is offline
Senior Member
VAPS: 6 Games
m_mcgovern is an unknown quantity at this point
Default
Smash + Total Carnage in a single cabinet is a sweet set-up. I've seen others do it by swapping the boards back and forth, but these two were made for each other. Please keep me posted on this project.
__________________
Games - Sinistar, 25" Smash TV, Major Havoc 720, Star Wars cockpit, Robotron cocktail, Warlords cocktail
  #3
Old 06-30-2009, 06:10 PM
pseeds's Avatar
pseeds pseeds is offline
Extreme Message Poster
VAPS
  Videogame:   43
  Video Board:   26
pseeds is an unknown quantity at this point
Default
I was looking at doing this as well. Thanks for the info.
__________________
si vis pacem, para bellum
  #4
Old 07-01-2009, 09:56 AM
slac slac is offline
Senior Member
slac is an unknown quantity at this point
Default
I was wondering the same thing about the player 1 and 2 for total carnage. I was thinking of doing the same thing but total carnage is nowhere near as fun smash tv. Swapping boards does suck since you have to go through the back of the cabinet.
__________________
Working: MKII, Smash TV, T2, Marvel vs Capcom,Sega Super GT twin, Neo Geo 6 slot, Outrun
PCB: Total Carnage, MK1, Gigawing, SFII CE, Macross
Pins: Spy Hunter
Wanted: Lethal enforcers
  #5
Old 07-01-2009, 10:03 AM
jow's Avatar
jow jow is offline
VAPS: 4 Games (2 W)
jow will become famous soon enough
Default
Thanks for the info. I was going to use this for my MK/MKII setup but Im wondering if it will screw it up?
__________________
WTB: Zoo Keeper
  #6
Old 07-01-2009, 10:29 AM
dmbj's Avatar
dmbj dmbj is offline
Senior Member
VAPS: 25 Games (2 W) / 2 Boards
dmbj is an unknown quantity at this point
Default
I MUST finish up a few things first but you guys are making me pull my smash tv out and finish it. Now that I know where to get the CP overlay I can't wait to finish it up.
BTW: pin 25 is not used in the jamma standard. but there are a few boards that use it. I think Neo-Geo's use it for button 4 so maybe check out the Neo message boards for some info on this. When it is done and working that is gonna be a kick ass machine.
here is mine. when i got it, it was a golden tee
  #7
Old 07-01-2009, 06:29 PM
m_mcgovern's Avatar
Senior Member
VAPS: 6 Games
Default
Quote:
Wow. Already I can see your marquee is much nicer and not nearly as faded as mine...
__________________
  #8
Old 07-03-2009, 04:41 PM
JeffC's Avatar
Senior Member
Post
Success!!! – http://www.youtube.com/watch?v=vzmUgNVB3_Q
It turned out to be much more of a project than I anticipated, but I now have this working perfectly.
Issue one was the missing control to shoot right. This was remedied by soldering a wire to the Jamma adapter at pin 26 and c at the connection to the Smash TV board, then tying them to the outputs from the Total Carnage board as well as the main game harness.
The second was a sound issue that should have been simple, but took me forever. I wasn’t able to get sound to work with both games, through the same POT, which was how I kept trying to wire it. One game would work, and the other would be at full volume. In the end, I wired a second volume pot, and everything worked perfect.
Last was the switching function, which is done by pressing player 1 & 2 start simultaneously. Since these buttons are used for gameplay in Total Carnage, I opted to disable the P1+P2 switching, and add a small button through an existing hole in the cabinet.
On the left is the Smash TV CPU, with the sound board behind, and the Jamma adapter above. Going across is the Jamma cable that’s included with the adapter. On the right are the Total Carnage CPU and sound boards.
The adapter PCB, the blue and purple wires were added for the missing “shoot right” control.
The extra volume pot I added, and the small button to switch between games on the right, just outside the coin door.
Check out the video at the top of this post to see it working.
__________________
The 720 Zone
  #9
Old 07-03-2009, 04:51 PM
pseeds's Avatar
VAPS
  Videogame:   43
  Video Board:   26
Default
Really cool. Thanks for sharing the info on how you made it work.
__________________
  #10
Old 07-03-2009, 05:19 PM
m_mcgovern's Avatar
Senior Member
VAPS: 6 Games
Default
Very cool! Thanks for sharing the details...and...
Success!!!
nice picture with the Quantum peeking through the coin door, taunting us all!
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Total Carnage discuspro69 Trading: Videogame and Pinball - Wanted 10 04-09-2009 08:51 PM
Total Carnage Jamma PCB Flawless and Complete POSFORNJKI Trading: Videogame and Pinball - For Sale 3 09-22-2008 12:52 PM
For Sale: Total Carnage PCB Jamma Complete Perfect POSFORNJKI Trading: Videogame and Pinball - For Sale 0 09-06-2008 02:22 PM
WTB : Total Carnage PCB kaz1961 Trading: Videogame and Pinball - Wanted 2 04-09-2006 07:00 PM
Anyone else here own a Total Carnage? KrK General Arcade and Videogame Discussions 10 08-12-2003 01:01 PM
Search Machine Encyclopedia:
