Return Home to Main Site |
#1
In this thread I'm going to document building a 25" AMP XY Color Vector monitor from scratch using the Dezbaz PCBs for Deflection and HV and various other parts as directed by Dez and everyone else that has helped out on this subject.
I've never even come close to building something this complicated before and have hardly any electronics experience, but I think with patience, careful reading and the support of this community I can do it. If I pull this off then I'll have an 'almost new' 25" Color Vector with an AMP/Zenith tube for my Star Wars cockpit build. Parts list owned/ordered/inbound. Sourced Myself Zenith 25" A63AAX02X tube made in 1987 ![]() ![]() WG 19K6100 Yoke WG 6100 Flyback AMP Flyback Bought From Dezbaz Deflection PCB Deflection Posistor (For degaussing) Neck Connector, 12 Pin for HV HV Mystery Can MC1 HV Bare PCB HV Metal Heatsink "C" Shaped HV Metal Bracket - to hold the Focus Block HV Glue Lined Tubing (Heat-shrinkable) HV Driver Transformer T1 Bought From Takeman Reproduction AMP Deflection Heatsink Parts List from Mouser & Other Sources Deflection Board Parts List HV Board Parts List Last edited by Griffin; 09-23-2013 at 08:18 AM. |
#2
Nice! The tube and yoke are the hardest part, and you've found the right ones!
Note that you won't need the 6100 'flyback' http://www.gauck.com/arcade/Amp25/Am...-in-a-box.html |
#3
The 6100 flyback is for a mod on the HV board. Still waiting on parts to come in before I can move forward on this.
#4
Ah, for the focus block, of course.
#5
#6
Just take your time. Using the 6100 yoke with the 25" tube should be easier to get good results. Rather than having to wind ferrites like my route took me. Going to try different tubes and try to get a 25" together for the ZVGVector build.
#7
Best of luck with this, I await your progress.
__________________
Cabs: Asteroids Cabaret; Tempest Cabaret, Star Wars UR (Amp); Missile Command UR; Pac-Man UR; Taito Space Invaders UR; Astro Blaster UR (white melamine); Defender UR; Gravitar (Running Amp & Zektor Multi-Vector); US Robotron Upright. |
#8
Quote:
at least it's all labelled and packaged he he
#9
will be following with loads of interest. if you can pull it off. that would be epicly awesome.
#10
Most of my gear is in now. A big thanks to DezBaz for getting this to me safely all the way from down under. Hopefully this week I will be able to get started on this.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Building a Marvel vs. Capcom 2 from scratch | skullin | General Arcade and Videogame Discussions | 22 | 07-19-2013 06:14 AM |
| Building from scratch | A.J. | Restorations, Cabinets, and Cosmetics | 16 | 03-23-2011 07:11 PM |
| Building a game from scratch | Atlas100 | Restorations, Cabinets, and Cosmetics | 7 | 09-24-2010 11:31 PM |
| building Puckman from scratch | racerx1690 | Technical - Videogames - General Repair And Help | 17 | 11-27-2008 08:45 AM |
| Building Galaga from scratch.. | pachi23 | General Arcade and Videogame Discussions | 5 | 06-13-2002 01:47 PM |
Title | Watchers | Time | Price |
| Bally ABC Ball Bowler 14 ft | 34 watchers | 2 weeks, 1 day | $2100.00 BIN |
