Return Home to Main Site |
#11
Quote:
__________________
Cheers . Dez . . Amazing Arcading XY Web Store & Links (Updated 10-April-2015) WG6100 Site - Hi Res Schematics (Updated 04-Dec-2014) PAT9000 Site Facebook site NEW |
#13
Quote:
So one example, in regard to U11, I see there is 11A, B, C and D, and U11PWR So the symbols that look like an op amp operating a switch, are obviously inside U11. And the power diagram (Bottom right) is drawn to simplify things but all them ICs need +12 (or +13v) AND -4v. (EDIT: OOPS, looks like -12V) not -4 It makes more sense the longer I study the diagram actually
__________________
#14
Followed this on the vectorlist with great interest. I hope someone will actually build and sell them since I sure would want one !
One question, is there no Z control or is it jsut because you hooked it up to a scope that we dont see it. I once hooked up my SW to a scope and had similar results...
__________________
www.eurocade.eu Last edited by Level42; 02-29-2012 at 10:59 PM. |
#15
Quote:
Not sure exactly what that fet switch does; but it's obviously tied into the opamp circuit. Looks like it turns the opamps into a unity gain opamp when "directed" by the software in the eproms. Quote:
Quote:
Should know more once I hook it to my actual Vector monitor. Last edited by Zitt; 02-29-2012 at 11:11 PM. |
#16
I'm following this. . .will want to build one when you are done!
__________________
Willy's Arcade on Facebook |
#17
Awesome effort - one thing that would make it over the top for me is if you could add a moving trace mode. I've had monitors work great with stationary vectors but if they move then the monitor has issues.
Bill |
#18
This past weekend; I created a cable to connect to my G08 monitor.
Overall the generator worked like a charm - I was able to get the monitor converged. ![]() I can't explain the center vectors... nor why the lines become squiggly. They don't move; it's always that way. ![]() Strange that the sight pattern doesn't seem to suffer from odd vectors. Box & Cross
#19
H Lines:
![]() V Lines: ![]() H&V Lines: ![]() As you can see; the generator works well enough to converge a vector monitor... At this point I'm not sure if the odd vectors / none straight vectors are the result of a software problem (EPROM images) or a hardware problem. It's possible the software isn't reacting well with the faster hardware (HC logic, better opamps); but unsure. |
#20
Pretty neat.
Certainly it's something on the generator. The images on the monitor look just like the ones on the scope. And I'll bet the scope can handle images a LOT faster than the G08 can do. Kerry |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| pattern generator | security0001 | Technical - Videogames - Monitors | 0 | 01-14-2012 09:14 PM |
| Pattern Generator | JoeB1355 | Technical - Videogames - Monitors | 8 | 12-01-2011 08:03 PM |
| wtb pattern generator | paul400 | Trading: Videogame - Wanted | 9 | 11-30-2011 12:18 PM |
| looking for pattern generator | paul400 | Technical - Videogames - Monitors | 4 | 08-18-2011 02:29 PM |
| Pattern Generator | shilmover | General Arcade and Videogame Discussions | 14 | 05-28-2009 05:28 PM |
Title | Watchers | Time | Price |
| Bally ABC Ball Bowler 14 ft | 34 watchers | 2 weeks, 1 day | $2100.00 BIN |
