KLOV/VAPS Coin-op Videogame, Pinball, Slot Machine, and EM Machine Forums - Hosted by Museum of the Game & IAM Return Home
to Main Site
Go Back   KLOV/VAPS Coin-op Videogame, Pinball, Slot Machine, and EM Machine Forums - Hosted by Museum of the Game & IAM > Arcade and Amusement Machines > Technical - Videogames - General Repair And Help
Register iTrader FAQ Calendar
Reply
Thread Tools Display Modes
  #1
Old 06-08-2011, 05:03 PM
jetusenet's Avatar
jetusenet jetusenet is offline
VAPS
  Videogame: - 4W
  Video Board: 1 (1FS)
jetusenet is on a distinguished road
Default GRAVITAR - Strange display
Hi;
I have a Gravitar that worked until I fixed it!
The display is garbled and instead of the usual coming up slowly when powered up, the display is dark then the display "pops" up, already bright etc......
Anyway, it has a Clay AVG replacement board and D102 is bright when the game is fired up but D101 is dim.
I poked around the PCB on the bench and found C110 broken, so I replaced it and IC A/B11-7 was bent underneath the IC so I straightened that out as well. Funny how the game worked even with those 2 components not quite right.......
I think that maybe the AVG PCB is bad, as indicated by the dim LED but before I replace that with a good one and possibly damage that one, I would like to get some opinions on why the one LED is dim.
Thanks much
Jeff
__________________
Looking to acquire:
Barrier
Sundance
QB-3
  #2
Old 06-08-2011, 05:04 PM
jetusenet's Avatar
VAPS
  Videogame: - 4W
Default Monitor shots
These are the pics of the display...........
__________________
Looking to acquire:
Barrier
Sundance
QB-3
  #3
Old 06-08-2011, 05:07 PM
jetusenet's Avatar
VAPS
  Videogame: - 4W
Default
To claify what I had meant by "fix it"....
I rebuilt the power brick, the A/R II, replaced the line cord and rebuilt the Monitor. I tested the monitor on a SD and it worked fine so that is not the problem......
Jeff
__________________
Looking to acquire:
Barrier
Sundance
QB-3
  #4
Old 06-08-2011, 07:04 PM
kstillin's Avatar
kstillin kstillin is offline
VAPS
  Videogame: 46 (11FS)
  Video Board: 1
kstillin is a jewel in the roughkstillin is a jewel in the roughkstillin is a jewel in the rough
Default
What happens if you jiggle the power connector?
Sometimes mine comes up with some jaggled/jumbled/jumpy vectors and it straightens out if I power down/back up.
  #5
Old 06-08-2011, 10:41 PM
jetusenet's Avatar
VAPS
  Videogame: - 4W
Default
Which connector are you taking about?
My concern is that the one LED on the AVG PCB is not as bright as the other and I feel that it indicates a problem somewhere.....
__________________
Looking to acquire:
Barrier
Sundance
QB-3
  #6
Old 06-09-2011, 06:21 AM
kstillin's Avatar
VAPS
  Video Board: 1
Default
I was talking about the PCB edge connector. I don't recall if it was the long or the short one. I just use the power switch to cycle it if it starts off bad now.
  #7
Old 06-09-2011, 06:29 AM
jetusenet's Avatar
VAPS
  Videogame: - 4W
Default
I came across a Black Widow that did that once, I would cycle the power and it would clear up....
But unfortunately, it does not work in this situation, I tried several times.
I will check the edge connector but I feel that the LED on the AVG PCB is trying to tell me something.
Thanks for the suggestion though.
Jeff
__________________
Looking to acquire:
Barrier
Sundance
QB-3
  #8
Old 06-09-2011, 09:26 AM
electrotim electrotim is offline
New Poster
electrotim is on a distinguished road
Default
D102 will be dimmer than D101.
See http://www.multigame.com/137179.PDF
  #9
Old 06-09-2011, 11:26 AM
MajorHavoc's Avatar
MajorHavoc MajorHavoc is offline
VAPS
  Videogame: 8
  Video Board: 235
MajorHavoc will become famous soon enough
Default
Need to isolate which part is the problem:
PCB, AR2, power brick (I see you already verified the monitor is good)
I know you are dialed in on the PCB already. But since you made changes to both the AR2 and power brick, it would be a good idea to verify that your focus on the PCB is the right direction.
__________________
Generic Signature
  #10
Old 06-15-2011, 07:55 PM
jetusenet's Avatar
VAPS
  Videogame: - 4W
Default
This is one for the history books........
It seems that it was not me after all, it had something to do with the monitor/PCB combo, they will just not work together!
I swapped the A/R II and power brick with known good working and still had the same problem.
I hooked up the monitor to another Gravitar cab and it worked fine.
I put the Gravitar PCB in question into the same cab and BAM, it no work!
I replaced the deflection PCB - NG.
I replaced the HV cage - NG.
I swapped monitors and BAM - it works!
So...... what I had to do was to replace the PCB in question with the replacement, use the original rebuilt monitor, A/R II and power brick and now everything works proper.
Has anyone else ever had a PCB that was incompatible with a monitor before!?!?!
Very weird.....
Jeff
__________________
Looking to acquire:
Barrier
Sundance
QB-3
Reply
Bookmarks
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
WTB: Gravitar kit for Gravitar/Black widow/space duel cab khabbi Trading: Videogame - Wanted 0 11-30-2010 04:13 AM
Gravitar - crooked display Timbo Technical - Videogames - General Repair And Help 2 11-10-2010 07:03 AM
Star Wars WG 6100 - display problem - bottom of display warped jehuie Technical - Videogames - Monitors 1 10-16-2010 07:10 PM
WTT: 2 Gravitar boards for 1 working Gravitar board DPtwiz Trading: Videogame - Wanted 0 07-21-2010 08:47 PM
WTB 14 digit display for Bally 6803 pinball game (Strange Science) 2PacMan Trading: Videogame - Wanted 0 12-13-2009 05:21 PM
Title Watchers Time Price
DONKEY KONG Classic Arcade Game Machine - Works Great! 66 watchers1 week, 6 days
$2495.00
BIN
Search Machine Encyclopedia:
Other Online Forums: Lymphoma Support
© IAM. All rights reserved. All times are GMT -8. The time now is 12:30 PM.
