Return Home to Main Site |
#1
I am swapping my old Amp tube with a NOS one. I've removed the rings, the yoke, and I have pulled the tube from the cabinet. I have a few questions though.
There is tape around the neck of the old tube. See the first pic. Do I need to put a similar type of tape on the new tube? There is tape inside the yoke. See pics 2 and 3. Should I leave it there or remove it? The yoke windings are dirty. Would it hurt to wipe down the windings with a dry rag? http://cid-4127ea3a33b50049.office.l.../tubeswap1.jpg http://cid-4127ea3a33b50049.office.l.../tubeswap2.jpg http://cid-4127ea3a33b50049.office.l.../tubeswap3.jpg http://cid-4127ea3a33b50049.office.l.../tubeswap4.jpg Thanks, Kent |
#2
Do you mean the strips here:
![]() Those are the strips to be used to do the edge convergence (see my video about doing this, but this is the LAST step !: http://www.youtube.com/watch?v=QYB1L8AIeq4) The tape on the yoke I would definitely leave, it looks like it's holding the wiring in place !!! Please post everything about your swap here, I'm going to have to swap a 25" tube on an Amplifone (yikes !) soon !!
__________________
www.eurocade.eu |
#4
ooops ... just read your whole response ... the white tape is on the old tube ... not certain if I need it on the new one ....
#5
I really have no clue about that tape around the neck....anyone else ??
__________________
www.eurocade.eu |
#6
When I swapped the tube in a 6100 it had some tape like that under the yoke. I don't know if it is required or not, but it seems to be a nice buffer for tightening the yoke enough to not move while helping prevent you from cracking the neck in doing so. So I put tape on the new one. I had some really similar bandage tape that I used.
#8
Like I mentioned in the first reply:
It looks like that tape is also holding the wiring in place. Definitely leave it there ! (Also for the reason VectorJunkie mentions...)
__________________
www.eurocade.eu |
#9
ok ... thanks ... got to read more carefully ... I just discovered that the tape is more than tape ... under each strip is what appears to be a magnet ... I'll post a pic in a second ...
Kent |
#10
O wow, that's very interesting !!!
__________________
www.eurocade.eu |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Tube swap convergence: when do you decide the tube quality isn't good enough? | TheShanMan | Technical - Videogames - Monitors | 14 | 02-02-2012 05:28 PM |
| Tube swap 13 pin neck sanyo w/19 inch tube | Thomas | Technical - Videogames - Monitors | 10 | 08-30-2010 02:01 PM |
| tube swap candidate? & other tube swap questions... | joemagiera | Technical - Videogames - Monitors | 2 | 07-11-2010 06:18 PM |
| Tried a tube swap.... WG4600 Chassis, Hantarex 9000 Tube.... | keithsarcade | Technical - Videogames - General Repair And Help | 11 | 06-11-2009 06:37 PM |
| Tube swap WG 7400: donor tube mounts forward | saltbreez | Technical - Videogames - General Repair And Help | 4 | 04-07-2009 05:56 AM |
Title | Watchers | Time | Price |
| THE SIMPSONS 4 Player Arcade Game Machine - Works Great! | 100 watchers | 2 weeks, 2 hours | $2995.00 BIN |
