KLOV/VAPS Coin-op Videogame, Pinball, Slot Machine, and EM Machine Forums - Hosted by Museum of the Game & IAM Return Home
to Main Site
Go Back   KLOV/VAPS Coin-op Videogame, Pinball, Slot Machine, and EM Machine Forums - Hosted by Museum of the Game & IAM > Arcade and Amusement Machines > Technical - Videogames - General Repair And Help
Register iTrader FAQ Calendar
Reply
Thread Tools Display Modes
  #1
Old 07-16-2010, 06:34 PM
Riptor's Avatar
Riptor Riptor is online now
VAPS
  Videogame: 22 - 2W
  Pinball: 1
Riptor has a spectacular aura aboutRiptor has a spectacular aura about
Default Promlink 6.1 and DATA I/O 29B & XP
Has ANYONE succesfully gotten a 29B to talk to a pc running XP? If so, whats the secret?
__________________
No repair work being accepted until further notice(begging wont help). TwistyWrist Arcade website is now back up and running. Please contact me if you find any bugs.
www.twistywristarcade.com
MCR Cables now back in stock 8/26
  #2
Old 07-16-2010, 07:27 PM
channelmanic's Avatar
channelmanic channelmanic is online now
VAPS
  Videogame: 4
  Pinball: 1
  Arcade/EM: 1
  Vending: 1
channelmanic has much to be proud ofchannelmanic has much to be proud ofchannelmanic has much to be proud ofchannelmanic has much to be proud ofchannelmanic has much to be proud ofchannelmanic has much to be proud ofchannelmanic has much to be proud ofchannelmanic has much to be proud ofchannelmanic has much to be proud ofchannelmanic has much to be proud ofchannelmanic has much to be proud of
Default
What cable are you running? What are the serial port settings?
RS-232 is a finicky thing. You have to use the right cable, right baud rate, and the right number of start, stop, and data bits too...
RJ
__________________
Call me a cheap bastard... I learned to fix things to save money... even surface mount soldering...
Visit my website: http://www.arcadecomponents.com
My repair logs have moved to NewLifeGames.com!!!
  #3
Old 07-16-2010, 09:05 PM
kstillin's Avatar
kstillin kstillin is offline
VAPS
  Videogame: 46 (11FS)
  Video Board: 1
kstillin is a jewel in the roughkstillin is a jewel in the roughkstillin is a jewel in the rough
Default
I've got a 29B with a unipak 2.
The only software I can get to work on a laptop with XP is the promlink341-1991 that can be found out on the net.
I have to force the command window into 'dos mode', which is what I call it. I do this by calling an older executable like 'edit'. The old dos editor forces the command window to a smaller size and the directory names display in the /x format like c:\dataio\promli~3 .
Then promlink can start with a command to feed it your custom init file like
pl my_29b
The my_29b file has all the saved parameters in it from a session you know runs.
I just tried again with the 6.1 directory and I always get some error in module blah blah or something.
I know the older software version doesn't support all the chips that the programmer can handle, but it's all I know. I haven't seen any better help out there.
Good luck.
  #4
Old 07-16-2010, 09:08 PM
orion3311's Avatar
orion3311 orion3311 is offline
VAPS
  Videogame: 21 (2FS) - 1W
  Video Board: 3
  Pinball: 3 - 1W
orion3311 is on a distinguished road
Default
You may want to adjust your serial port baud rate in device manager...
__________________
Doing a TV tube swap? My Donor TV List: www.junknet.net/donor-tvs :::: Items For Sale
TV Tube Swap Guide: www.junknet.net/tube-swap-diy-part1 :::: Website: The MadMan Arcade
  #5
Old 07-16-2010, 09:37 PM
Zinfer's Avatar
Zinfer Zinfer is offline
VAPS
  Videogame: 64 - 9W
  Video Board: 13
  Pinball: 1
Zinfer will become famous soon enough
Default
I attempted to run the very unit your talking about. I believe I ran it on win98. It would appear to work for a bit, but then it would knock out the serial port to where it wouldn't communicate any longer. I replaced like 3 serial ports before I called it quits with that. I've still got it but it's sat for a number of years.
They have better things out now, but it'd be interesting to try a serial to usb adapter on that and I bet it'd work.
__________________
zinfer.com
  #6
Old 07-17-2010, 02:05 AM
Paul Olson's Avatar
Paul Olson Paul Olson is offline
VAPS
  Videogame: 6 - 3W
  Pinball: 5 - 1W
  Arcade/EM: 2
Paul Olson will become famous soon enoughPaul Olson will become famous soon enough
Default
If I remember right, the software was looking for a different COM port, and I couldn't find a way to change it. I need to pull it out again and try to figure it out.
  #7
Old 07-17-2010, 04:33 AM
mrbill08's Avatar
mrbill08 mrbill08 is offline
mrbill08 will become famous soon enough
Default
it will work with the modified promlink software that you can find on the web - leopardcat's data i/o resources site:
http://www.retroclinic.com/leopardca.../dataio29b.htm
You run the modified promlink in a dos window and you will get an error about a com port not being found. Going from memory, it is looking for com2: even though it does not need or use it in default mode (it uses com:1). Com2: does not exist on most modern pcs and notebooks. Just click ignore.
Set baud rate on both the pc and data i/o to a baud rate that works with no parity 8 data bits and 1 stop bit 9600 , n, 8, 1. You can try higher baud rates once you get things working at 9600.
Most important is the proper "null" modem cable. Directions and a diagram for the null modem serial cable can be found in the data i/o manual or again on leaopardcat's excellent resource page:
http://www.retroclinic.com/leopardca...taioserial.htm
I've done this on several older pcs with good results and one that did not work. On the one that did not work, I probably would try a plug in serial card or USB to serial but had enough old pcs that I did not need to try it.
Have fun and once you get it set up, document what you did.
Last step is to put the data i/o into serial external communications mode:
On the 29A or B keypad, press "select", "F", "1", "START", "START"
(yes you have to press the "start" button twice).
Have fun and if you need any more advice, the folks who have Data I/Os can assist. This is the most reliable programmer of all of the ones I've used. It's a clunky beast but has never let me down for the older proms and eproms.
Bill
  #8
Old 07-17-2010, 05:33 AM
Riptor's Avatar
VAPS
  Videogame: 22 - 2W
  Pinball: 1
Default
Bill, done all that. The cable im using is actually one I made for Billys 29A so I know thats good.
Here is another weirdo thing. When I fire up the 29B it goes straight into remote mode.
Anyone have device code and faimily pinout list or know where I can find them?
__________________
  #9
Old 07-17-2010, 09:17 AM
Thomas's Avatar
Thomas Thomas is online now
Thomas is an unknown quantity at this point
Default
I am still not sure that cable is right. I found very conflicting information on the cable.
All the software is stored inside a picture on the group site.
http://tech.groups.yahoo.com/group/Data_IO_EPROM/
If you unpack the picture with 7zip you will have all the files the yahoo group keeps for everyone.
I would join and then post to the data i/o group if you have any problems. They always answer the questions sent and all the answers have a special place in my inbox!
  #10
Old 07-17-2010, 09:20 AM
Thomas's Avatar
Default
Lets see if I can get some relevant links up. Also you know I have all the manuals for every one of my adapters and the 29.
http://tech.groups.yahoo.com/group/D...OM/message/311
http://www.pestingers.net/Data_IO_29B.htm
These few posts below should put you right on target...
http://tech.groups.yahoo.com/group/D...OM/message/242
Quote:
What would the best SW package to use with this programmer? I saw mention of PL6.1 and other SW versions. A Version 01 - 05 would work best with PL3.4 as it uses only 4 digit family/pinout codes. PL 6.10 works with a Version 06 29B with 6 digit family/pinout codes. 6 digit codes were added starting at Unipak 2/2B Version 15.0
You might need to upgrade that beast to get 6.10 working!
Hope that last link above help...
Also this pdf below is awesome...
http://www.pestingers.net/PDFs/Prom_...Note_Jul85.pdf
Hear is a complete list of packages than can be burned with the right combination of the 29, pack & software revisions
http://xa.yimg.com/kq/groups/2539181...me/unipak2.PDF
Reply
Bookmarks
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Data I/O Guru's 29A vs 29B Thomas Technical - Videogames - General Repair And Help 23 01-02-2015 03:24 PM
FS: Data I/O 29B troxel Trading: Videogame - For Sale (Whole Games) 7 04-28-2010 06:23 PM
WTB: Data I/O 29b Paul Olson Trading: Videogame - Wanted 0 08-25-2009 03:38 PM
Data I/O Promlink and XP Atari Force Technical - Videogames - General Repair And Help 4 06-03-2009 01:08 PM
Data io 29b teckkev Technical - Videogames - General Repair And Help 3 05-27-2009 07:10 PM
Title Watchers Time Price
Wurlitzer 15" Field Coil Speaker 16 watchers7 hours, 32 minutes
$20.50
Auction
Search Machine Encyclopedia:
Other Online Forums: Lymphoma Support
© IAM. All rights reserved. All times are GMT -8. The time now is 12:28 PM.
